Looking for a script that would delete all of the inside lines after trimming
9682.2 In reply to 9682.1
Hi Johnny, select all the curves and run Construct > Boolean > Union instead of using Trim.
You can also use the boolean commands on curves as well as solids, they are sort of like a "batch mode" that combines Trim + automatically deciding which pieces to discard and keep + Join.
