Shortcut and Scripts Support
9680.2 In reply to 9680.1
Hi tsiwt, the philosophy for MoI's shortcuts system is that the shortcuts are a personalization function that you can tune to your own preferences.
There is not an emphasis on having an extensive default set of shortcuts. Actually more the opposite of that - the original concept for MoI was that it could be used easily on a tablet without needing to touch the keyboard at all.
But if you want to have a bunch of predefined shortcuts that someone else has designed for you, there are some available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8123.1
The above thread can be found by doing a forum search for "shortcuts" targeting titles only.
Also the tutorial from Arrimus3D includes a shortcut key setup I think, there is a link to that at http://moi3d.com/resources.
