Hi Stefan, objects only show up in the browser if they are assigned an object name, and they are displayed in alphabetic order there.
So to use the browser order like you're describing you would need to assign an object name to each individual object that you wanted to have in the gradient and make the names in increasing alphabetic order.
That seems kind of cumbersome but it could be possible to set it up that way if that would work best for you.
It would probably help if you could post an example file that had the objects in it that you wanted to apply the gradient onto.
