Color Gradient script?
9676.19 In reply to 9676.17
Hi Stefan,
> What I had like seen, as I described, is to have in the script a way to select a starting and an end
> color, while the script computes then the steps betweenthose two colors.
It should be possible to make a script that does this.
What color space do you want to use for specifying the colors?
If using RGB colors, going from Red to Red like you mentioned above would only yield red for all the steps in between.
But something using Hue, Saturation, Value colors could probably give more of a rainbow type effect.
