[NodeEditor] How i can Filet / Chamfer Points (corners) from a Rectangle Node ?
9666.13
thanks everyone for your reply.
I ended up with a solution based on Pilou observation via a trim node and few other math nodes, but it still miss the Chamfer node as bemfarmer says.
Edit:
To create the same behavior as a Chamfer node, i used the Filet2 node in Continuity Mode: G2 and a Bulge at 0
EDITED: 31 Jan 2020 by SMOLUCK
