V4 beta Jan-22-2020 available now
9660.81 In reply to 9660.78
Hi Ken,
> However on the AMD Ryzen 7 I do not have these icons.
That's normal, those icons are not part of the default MoI install, they are part of a customized UI plugin written by Max Smirnov like Pilou writes above.
> How do I enable them?
You would need to install the CustomUI modification on the above link.
I would recommend holding off on that for a while until you get accustomed to using the normal MoI installation first.
Most of those icons you show there can already be found on the side pane - "Sel all", "Desel all", and "Invert" can be found on the side pane under the Select tab. "Image", "Cplane", and "Reset all" can be found on the side pane under the View tab, "Hide" and "Lock" can be found under the Edit tab, and "Horiz center", "Top", "Bottom", "Vert center", "Left" and "Right' are inside the Transform > Align command.
