V4 beta Jan-22-2020 available now
9660.37 In reply to 9660.36
Hi Lewis,
> Is there way to set TEXT font size for dimension stool (i find ti too small by default)
You can set the text size by clicking on the Font value here:
That way (using the properties panel for the selected object's properties) will change just what is selected. To change the defaults for newly created dimensions go to the Options dialog Dimensions section and set the preset's Font value.
> and is there way to show UNITS also ? I'd like to see meters/centimeters or any other user picked unit (in preferences)
> visible on the dimension line also.
You can customize the text content by editing the "Text" value that is just above the Font.
Put in your units label after the <> , so have it like: <>cm for example. The <> will be replaced by the dimension value.
There is not currently a way to set a units label for the default text. At some point in the future I would like to support other types of variables but that won't be ready for v4.
Hope that helps!
