Hi Chri,
> Does the SPLIT script work with MoI 5.0 beta Apr-8-2023 to obtain section like the example ?
I'm not familiar with the "split" script, can you show me where that is located?
But you can use the regular boolean difference command to make a cut like that.
Draw in your parting line like this:
Select the objects and run Construct > Boolean > Difference. Then select the line at the cutting object:
> Or have you planned a "section view" function ?
I would like to have a section view function but I'm not sure when it will happen.
