Script Runner
9638.4 In reply to 9638.3
Hi Quaritexa,
> And how do you change the focus on the menu items?
I'll probably need some more detailed information on what you're doing. Are you using <moi:MenuItem> elements there and you want some of them to have a highlighted background?
If so you could try switching to <moi:ListItem> elements instead, a <moi:ListItem> inherits from StateButton which means it has a .value property and if that is set to true it will display with a different state.
A <moi:MenuItem> element does not have a built in way to display a different background like that, it only has a .checked property for showing a checkmark or not.
