Yep, this happens. Probably because the central point is going crazy with two boolean ops on top of eachother. Might be a problem with the operation and not the program per se. You can recreate this even if you union the two boxes and the base instead of subtracting them. This might not be a watertight volume as the vertical edge in the middle is being essentially removed by the boolean sub. Might be wrong though!
