Control Point Clean Up
9614.12
I send files for Cutting to an industrial laser and they run JETCAM and PEP Technology on their machines. Prior to creating a cutting path NC file both programs will highlight problem areas they put a circle highlighting flipped or duplicate points on a curve. They are both high end applications each seat costing thousands of dollars a year - So this solution offers the same result in a very elegant manor. I havent seen any auto repair tools out there as the coding to work out the scenarios for the errors would be highly complex. But once again MOI offers a simple solution to a common problem. Instead chasing countless points highlighting dense areas is usually a good starting point to a problem leaving the user to decide the best manor for clean up.
Thanks again.
