Control Point Clean Up
9614.11 In reply to 9614.10
Hi Stefan,
> I am wondering about the following, regarding those dense control points
> in the letters. Because MoI does not use Bezier curves like Illustrator what
> would happen for example if one loads those Bezier curves for example into
> ViaCAD (which I no longer have) and then change in there the Curve type
> to what MoI likes and then export and import into MoI.
Beziers are a subset of NURBS, so MoI can import a Bezier curve drawing from 2D illustration programs exactly.
Going the reverse direction can be more problematic - it is possible to break a NURBS curve into a chain of Bezier curves with the exact same shape, but if the NURBS curve uses rational control points (which will be the case for conics like circles, ellipses, ...) then you get a chain of rational beziers while the illustration formats only support non-rational beziers. So in that case there has to be a rebuilt curve exported instead of the exact curve.
But on the other direction there isn't any refitting, if there are a lot of points then that's just what was in the file.
> Would that get rid of the many control points?
If it did it would involve changing the shape by some amount.
