Node help
9608.3 In reply to 9608.2
rotating about the X,Y and Z is not my problem. The axis of rotation is around the pivot pin which is at 45 degrees.
In the photo I show a block and pivot pin square to the X,Y and Z axis so rotating around the pivot pin is no problem
but the second block & pivot pin are at an angle at 45 degrees and to achieve a rotation around that axis is my issue.
Barry
