Naked edges
9600.2 In reply to 9600.1
Hi Tim, a "Naked edge" is an edge that belongs to only one surface instead of where 2 surfaces are joined together.
The main use for identifying these is if you're trying to make your object into a closed solid. A closed solid needs to have all joined edges and no naked edges.
Also even if you're not making a solid it can help to identify if there are unwanted gaps in any areas.
