Boolean difference solids generates thin walls?
9592.1
Beginner here, so please forgive any obvious mistakes. I am trying to design a small object for 3D printing.
I have worked with solids all the way osing boolean commands with other solids to cut away until I reached this shape. There are no problems with faces, and the whole thing reports as a solid. However, when I export as STL and open in slicer or meshmixer, the object has tiny thin walls, inside and outside. I have tried to solidify the object but to no avail. It prints, but the outer walls are so thin the printer fails with certain spots. Also, it seems as though the rounded cylinder shape added into the center is actually truly solid in the stl.
Again, pardon my ignorance, but does anyone of you have any helpful pointers on where to go next?
