New Help making a Crown
959.6 In reply to 959.5
> It would be nice to have an option to only displacement curve along one axis
> when projecting it onto a surface. Currently, when the curve is projected,
> it deforms. An option to maintain its profile and only displace it on one axis
> instead of two would be nice.
Hi Twinsnakes, I'm not quite following this, could you please show an example of what you mean?
Projection should be happening along just one axis already - like in the crown example above when you do a boolean with a planar curve, the curve is projected just in one direction perpendicular to the plane of the curve.
So for example if you switch to the front view, the silhouette of the solid crown pieces line right up with the outline of the club curve.
If you are seeing something deform differently than that, it might be a bug...
