hotkeys on options
9589.2 In reply to 9589.1
Hi quaritexa,one way (in v4) is that you can set up a shortcut key that will run the Extrude command and set those controls to a specific value. To do that you add parameters after the command name in the shortcut key.
To run Extrude with "cap ends" always enabled, set this as your shortcut key:
Extrude capends=true
For "both sides" set this:
Extrude bothsides=true
To do extrude tapered with one shortcut key do this:
Extrude tapered
