Joined surface refuses to become a solid
9588.3 In reply to 9588.1
Hi Chris, in the current v4 beta you can use the detailed object properties dialog to find the naked edges.
Select your object and then push "Details..." here:
Then in the report that lists 5 naked edges, click on that text to select them so you can see the problem areas:
You can also set up a script on a shortcut key like Brian mentions above, the instructions for doing that are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
However, some of the problem edges here appear to be squished down micro edges which are harder to get rid of. I got rid of one area using the Merge command and in the second problem area I needed to untrim 2 surfaces to get rid of the bad edges.
I've attached a fixed up version that is a solid now.
