Custom UI Setup For Dummies
9586.4 In reply to 9586.3
Hi Brendan, so for that version you'll need to get the file CustomUI.1.03.win.mac.zip which is an attachment on the message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Unzip that and you should have 3 resulting folders that were in the .zip file:
objects
snapshots
ui
These need to be copied into the MoI install folder. The MoI install folder is at C:\Program Files (x86)\MoI 3.0
So copy the objects folder over so you have a folder C:\Program Files (x86)\MoI 3.0\objects
Copy the snapshots folder over so you have a folder C:\Program Files (x86)\MoI 3.0\snapshots
Now for the UI folder - there is already a UI folder inside of MoI's regular installation so for that one go into the .zip's UI folder and copy all the contents of it into MoI's UI folder at C:\Program Files (x86)\MoI 3.0\ui . There will be a warning that one file named CommandBar.htm will be overwritten, say yes to that.
After that it should be installed.
If you're still having difficulty please show a screenshot of what your installation directory looks like.
