Is the Shell operation supposed to work on tapered joined surface objects?
See attached.
I was attempting to make some ducting by lofting a pair of profiles and then giving the walls some thickness with the shell command.
While the shell command seems to work shapes with a little taper as the taper becomes more pronounced the shell results get strange.
And since shelling doesn't seem to be the correct approach what is the "correct" way to make ducts that have some wall thickness so they can be 3D printed?
Thanks again.
Frederick
