Hi Tom, yes the Edit > Extend command can be used to extend a curve.
For your case here you can get an extension by untrimming the surface to recover the full underlying surface and then extrude that edge. I've attached an example.
It's generally better to have done the extension on the original construction curves so the surfaces have that extension in them when you make them.
