Extend / extrude "tangentially"
9567.2 In reply to 9567.1
Hi Tom, currently the Extend command only works on curves, not surfaces. I want to change that in the future but typically the best way to make an extension like that is to extend the original curve used to construct the surface in the first place instead of trying to extend the surface after it has already been constructed.
If you can post the .3dm file I might be able to try out some things and give you some other suggestions though.
