Hide + show
9543.4 In reply to 9543.3
Hi Tom, sorry no there isn't anything set up for that. But if you want the same as "negative isolate", I'd think you could get that by inverting the selection and then using regular isolate... ?
It is also possible to show only some of the hidden objects and not all of them by using the "Show subset" function which you can access by a Ctrl+click on the Edit > Hide button.
"Show subset" will temporarily show all hidden objects but then will pause and let you select the ones of interest. When you're done selecting the ones that you did not select will go back to being hidden.
If you need more fine tuned control over hide/show instead of everything the other main way to accomplish that is to assign a name to your object so you can use the scene browser to hide and show it rather than the Edit > Hide button only.
