9526.163 In reply to 9526.161
Hi Mip,
> I'm experimenting the same problem as Tech (msg 9526.84) under MacOs 10.9.5.
Can you please send me an e-mail at moi@moi3d.com and I'll send you a build with a fix for this to test.
> As another subject, I would like to mention that when a Mac user tries to enter the diameter
> symbol 'ΓΈ' as an anotation prefix or suffix (or using the Text tool) by using the keyboard entry
> alt+o, it activates the Open dialog instead of entering the symbol.
Can you look in your shortcut keys in MoI under Options > Shortcut keys, is there an entry there for Alt+O ? If there is that's probably a remnant from v3, if you remove it can you then put it in ok?
Thanks, - Michael
