https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm#Nudge 这个地址的Nudge.zip和 CPlaneNudge.zip。网友报错,我没能复现这个报错。他使用的是自己弄的带有xml,css的运行脚本按钮的v3版本,我想问,是否有可能是因此造成冲突而报错?(The Nudge.zip and CPlaneNudge.zip files at this address. The netizen reported an error, but I was unable to reproduce it. He was using a v3 version of the UI with some XML and CSS running script buttons that he had created himself. I would like to ask if there is a possibility that this caused a conflict and resulted in the error?)
相应图片上传至图床(Upload the corresponding image to the image hosting service):https://i.imgs.ovh/2026/07/01/bda2ff7c46fdceed0df71032c6c0d94a.png
https://i.imgs.ovh/2026/07/01/c2cb3c43e3dd13a2f005f42338643646.gif
https://i.imgs.ovh/2026/07/01/ae9513e393c72c9496be4a4fa9ef121e.png
因为我不懂代码,所以我对MOI界面的修改都是基于原本样式的按钮,添加或删除相应位置的按钮。他怎么改的我并不懂,所以只是问一下可能的原因。(Since I don't understand code, all the modifications I make to the MOI interface are based on the original styled buttons, adding or deleting buttons at corresponding positions. I don't understand how he made the changes, so I'm just asking about the possible reasons.)
我使用了他发给我的UI包,也没复现这个报错。(I used the UI package he sent me, and I didn't reproduce the error.)
