Purchase
9514.5 In reply to 9514.1
Hi piazzafatb, you can install the same one purchased license on any number of your machines (like on both your laptop and your desktop) just as long as it is only actively launched and running on one machine at a time. To switch to a different machine you would just exit any running MoI program (not uninstall, just close the running program) on the one machine before launching it on the other.
You only need a separate license for different machines if someone else is going to be running it there the same time as you.
You don't need to do anything special to set up the multiple installs, you just use the same downloaded installer and same license key on each one.
