Fillets again
9501.3 In reply to 9501.1
I've attached here what it looks like putting in some fillet surfaces using surface/surface filleting. They kind of swoop off a long ways then you cut them back using Edit > Trim with the "isocurve" option.
Maybe blend is better than fillet anyway because notice how regular constant radius fillets do not naturally line up like you probably want at the trailing edge.
