scripts not working
9498.3 In reply to 9498.1
Hi Bruno, when MoI is not able to find a script file of that name in the commands folder it will try to run the text as direct script code itself which then gives that error.
So it means either the file is not in the right folder or your shortcut key name does not match the actual script file name. I think the file for sSplit is actually named _sSplit.htm , note the leading underscore. So your shortcut key needs to match that including the leading underscore, like this: _sSplit
> One of the scripts is supposed to come with an UI menu button but I'm not sure how to get that one to work either. Can you help?
Which script was that, can you post the address of where you got it from?
