Exploration of Scripting in MOI
9490.1
This is potentially a work in progress.
Any all comments/help are appreciated.
I am new to the API.
This is first attempt at scripting
I just hope this isn't recreating the wheel, and if .nod would not be the wiser choice
Q: Is there a way to automate iteratively the export of an object's rotated silhouette using Silhouette and Autorotate simultaneously?
Looking at the Silhouette and Autorotate scripts to see if a routine could be made / viable?
Is logic any good?
I am starting off with:
MOI open and running.
Start with object. Select object.
Maintain selection of object?
Silhouette, View in 3D, Incrementally rotate , silhouette object, Select silhouette then join/boolean, export silhouette, increment filename..repeat until Max file reached output or break! Show progress?
Notes:
- fstream out or buffer, saving each silhouette as joined or boolean,
- later to import and even if possibly concatenate those imported from the directory. CSV option?
- Do coords change upon incrementation / rotation of world coords ?
...if only I were more savvy, even so would it work?
None the less, it would make for an interesting script I think.
Any tips or help to create this would be appreciated.
Dave
