FORCE MOVE ALONG NORMAL.
9483.3 In reply to 9483.2
the script you did is working in part...still needs turn off vertical snapping as well....
i also cranked the active distance to 1000 and keep active distance to 1000....this helps slam it to force normal. :)
is it possible to trigger this behavior when using just the left mouse button move? as i click where i click it uses that normal....and locks to that path of travel.
