FORCE MOVE ALONG NORMAL.
9483.1
Hi Everyone.
i will make this brief:
i was wondering if there was away we could force move along eliv/normal only as a temporary script: ie once executed the move tool would return to normal function until script was run again.
my idea is a combo of the orient tool script:script: /* CPlane */ moi.view.setCPlaneInteractive(); and the straight snap options running/working together as you can already do but in a script.
a great example would be a sphere. i could run script: then where ever i click next on the sphere will be used to grab normal/eliv constrained to that only axis....until release
i think a tool like this would make for amazing work flow!
ps could it be possible to turn the orient tool into a sort of gizmo that you could move object using the 3 aligned arms.
