| One more try :-)
 Switch node:
 The Output is connected to either the top input, or else the bottom input, depending upon:
 Switch mode:
 Left click toggles between top input and bottom input.
 Changing to Button mode, in info window, connects the top input.
 Button mode:
 The pre-existing connection is with the top input.
 Left click with HOLD, connects the bottom input, until hold is released.  Then the top input is re-connected.
 Pilou, you are doing an excellent job!
