Can't erase ?
9457.5 In reply to 9457.1
Hi Pilou, yes probably something involving Elephant. There is a thing called "Selection lock" which is used in commands like booleans where you select objects in multiple stages. With a normal command it's automatically removed during the cleanup steps that happen when a command ends. Since Elephant does not run as a "command" it won't get that kind of cleanup done automatically. But it can also be done manually as well. It can probably be solved with some minor changes to Elephant if you can figure out how to repeat it.
