Curve from 2 views?
9440.3 In reply to 9440.2
Thx Pilou - that should be it. Haven't noticed those extra commands in curve section.
Sadly can't get it to work as "curve from 2 views". I've drawn a circle in front view, then a polyline (at an angle) in side, then tried the command and nothing happened. Same setup in Rhino works. What am I doing wrong?
edit: with ctrl point curve it works. hmmmm...
edit2: when ctrl point curve is aligned to form a straight line it does not work.
edit3: it seems that MoI assumes that if I create a straight line it should be projected / extruded in very specific direction (in my setup it means up/down), which is incorrect in this instance. Wonder whether anything can be done with it, without breaking correct behavior in other cases.
But at least in more complex setups, with more flowing curves where "curve from 3 views" is much more useful it works as it should :) .
EDITED: 24 Jul 2019 by PRZEMAS
