Permanently expanded side bar menu
9439.3 In reply to 9439.1
Hi Mark, so for v3 setting up the side pane like that would have involved editing the SidePane.htm file as described in these links:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8064.1
For v4 it's possible to set up a startup script that will do that, I've attached one here named SeparateSidePanePalettes.js . If you place that in your MoI v4's startup scripts folder I think that should do what you want without needing to edit any files.
The startup scripts folder is in your MoI appdata folder, on Windows that would be C:\Users\<username>\AppData\Roaming\moi\startup and on Mac ~/Library/Application Support/Moi/startup.
EDIT: updated script to work with the Oct-27-2020 v4 beta.
EDITED: 28 Oct 2020 by MICHAEL GIBSON
