Boolean stencil?
9436.14 In reply to 9436.13
< Did you download it, unzip it, and copy it into a commands folder?
Of course yes! :)
Edit : That works now for any reason!
That works as aspected but I don't see difference with my method above / final result...:)
Even it's perturbating if you select the cutting object and ask remove (after the mutual "OK" triming) you stay with just the intersection ! :)
So you must deplace it after the mutual triming!
TrimStencil here with 2 another volumes
It's not evident to have the remove of the cutting object!
We must make a Right Click and not Click on the "OK" button!
(here the extrude function after the TrimStencil)
EDITED: 22 Jul 2019 by PILOU
