A matter of technique
9419.41
If you really want to take advantage of manipulating the projected curve --where the surface is a cylinder, or something that will result in two projected curves -- just copy the surface (solid) to one side, cut it in half (eliminating the back side), project and manipulate the curve until you have what you want, then move that curve back onto the original surface. Remember to set the endpoints.
