MoI file to Blender > MoI
9415.7 In reply to 9415.6
A. Blender > MoI scale
"That's for your "Box_2_subD_test.obj" file?"
I tested a particular project file. The Blender units are set in Millimeters....and I have MoI set up in MM as well. If I switch MoI to Meters...I get the same scale issue import result.
Switching Blender export scale to 1,000 as you suggested works...and the x/y/z position is now also correct. Now the MoI import is much closer...still off by a tad though.
Blender
X: 210mm
Y: 428mm
Z: 42.4mm
MoI
X: 210.41 (Measures 210.38 when measured point to point in MoI, but 210.41 general measurement, see image).
Y: 427.79
Z: 42.37
Center to center measurement of the bars seems spot on at 403.55mm.
B. Import OBJ
- Took off the .htm and .js...still no go. Image attached.
Thanks Michael.
M
Size: 262.9 KB, Downloaded: 91 times, Dimensions: 1082x255px
Size: 30.2 KB, Downloaded: 55 times, Dimensions: 329x200px
Size: 76.7 KB, Downloaded: 55 times, Dimensions: 636x219px
Size: 141.2 KB, Downloaded: 59 times, Dimensions: 1234x150px
Size: 23.4 KB, Downloaded: 44 times, Dimensions: 491x92px
Size: 111.7 KB, Downloaded: 45 times, Dimensions: 1222x143px
Size: 75.2 KB, Downloaded: 53 times, Dimensions: 720x202px
