label mapping
9410.9 In reply to 9410.8
Hi suman, what are you going to be doing with the model, are you making a rendering with it?
It may be better to apply the label as a texture map in a rendering program rather than trying to model a thin paper thing like that in CAD.
If you did want to model it using Flow note that the label does not actually adhere 100% completely to the bottle in this area here:
So probably the first step would be to prepare a second revolve that does have the shape that the label should adhere to, meaning it would not have the inward jump and maybe have a little bulge for the wire.
Something maybe like this as the profile for the revolve:
Then you're going to use that as the target for the revolve not the original bottle itself.
Maybe some projected 2D curves onto that might be easier than Flow.
