Marco's UI works with the Beta V4?
9406.8 In reply to 9406.7
> I think that step 5 should be to the AppData command folder(?)
Yes, it's generally preferable to put additional commands into the AppData command folder so they don't have to be copied again with new installs which will be needed if you put them into the install folder instead. Probably Marco's UI was created before MoI v4 supported having commands in AppData.
> For MoI4 in general, Apparently the standard MoI commands need to be located in the MoI install folder?
Well they don't have to be, but it is recommended to leave the standard commands in the install folder.
> There is also a copy in Appdata, which I think can be deleted.
By default MoI places nothing in the AppData commands folder, anything that is in there would be copied in there by you at some point previously.
