Marco's UI works with the Beta V4?
9406.3 In reply to 9406.1
Hi Pilou & Stargazer,
> The original of Marco's UI
> http://moi3d.com/forum/index.php?webtag=MOI&msg=7862.1
> Doe's it working with the Beta V4 like the V3?
The original one does not work with V4 because it has some errors (mismatched start/end tags) in the HTML structure which v4 does not tolerate as much as MoI v3 did.
Also it needs a couple of other minor adjustments since MoI v4 uses the standard flexbox rather than the old deprecated Webkit specific one.
I've attached an updated version here, if you use the attached ScriptsGallery.htm in place of the original does it then work ok for you?
