View names and positioning objects
9399.1
Hi all,
I use MOI for designing various old-timer vehicles for 3D printing.
Let's take a bus. It's obvious what is the front or back, and which are the left/right sides. The length is several times bigger as width or height.
Drawing such an object in MOI results in a "conflict": If the front/back and left/right views are OK, the top view is "vertically" oriented, so the editing on wide screen monitor is not optimal. So I am using to draw such object placed the longest dimension along the X axis, and live with "confusing views", instead front/back I see left right side of the bus, and vice versa...
Is there a simple way (setup, script) to:
rotate the "top" view
or swap the front/back left/right button names?
(changing the X/Y labels in "options" does not have effect...searching these discussion several times also did not bring an effect)
Is there a way to see the split view "unevenly"?
e.g. bigger 3D view, smaller other views or wider top and front views and narrow 3D&left view
(I mean something like moving the center point of the spitted view)
Jozef
Size: 40.9 KB, Downloaded: 76 times, Dimensions: 855x541px
