NETWORK CURVES non pinch surface
9390.9
How did you get to show the control points?
Yes in creating the flow deformation I usually copy and past the target surface and flatten that down to 0 depth and use that as the base mapping surface so in theory should be same size.
I just tried it by same process but I offset reduced the base surface and then used the flow command and then boolean difference and it all worked smoothly - thats another great tip.
