NETWORK CURVES non pinch surface
9390.7 In reply to 9390.6
Hi Pilou, the current unit system doesn't really have any effect on decimal point accuracy, unless it also causes you to use large or small numeric values.
For example if you make a line and put in a coordinate of x = 4.0 y = 3.0 for the start point of the line, the line will have those numeric values x = 4.0 and y = 3.0 no matter what unit system you have set.
The unit system is more like an additional label that says to someone how those numeric values are supposed to relate to real world measurements.
That's how it works in MoI anyway, it is true that some programs do it differently like SketchUp I think translates everything you enter into inches I think. That can then cause some problems like you are asking about.
But MoI does not alter numeric values that you enter unless you ask it to by giving a different unit system at the end when you type in a coordinate.
