NETWORK CURVES non pinch surface
9390.2 In reply to 9390.1
Hi Alex, probably the best bet is something like the attached using Loft with Loft style = "loose".
You'll see something at the pole but it's just a display artifact from a low poly count there, make sure to do a higher density export to really see what the surface looks like:
Loose loft is usually the best way for these things but Network can also be workable if you add similar stations that progress towards a circle before it reaches the pole point. Basically you don't want a curve with different sized features like you have here with short corner areas, to slam directly down to a single point. It needs to sort of spread out to a circle before it comes down to a point.
