Import file - 'all supported' as default
9387.2 In reply to 9387.1
Hi agonyii,
> I would even make it default if you ask me overall considering this state does not seem to be saved.
It should be saved for any further uses during the same program session.
So for example if you do File > Import and then choose "All supported" and import a file, then repeat that process in that same running program session, it should default to what you last chose.
It's only if you completely exit the program and start up a new session that you should see a different result.
Is that what you are seeing there or do you not see any within-same-session saved state?
