Best way to select edges curves?
9385.3 In reply to 9385.1
Hi ColoristNow, also if you select one edge then you can do a selection window drag which will then target edges.
If you have an example model where you're having difficulty selecting edges if you could post the model file I may be able to give some suggestions.
