Flow behaving bad ;-)
9380.1
Hi all, I'm trying to bend a shape around another shape using Flow.
After selecting FLOW I canselect the object and base curve with no problem. When selecting the target surface however, I can only select the 'top part' which eventually projects the new object in a wrong shape.
Probably a user error ;-) But why can't I select the entire target surface? (I tried joining, boolean, redraw the shape, but no sucses).
Please take a look at the .gif. As you can see in the start of the video, Moi recognises the target surface as 1, until I select it after using FLOW.
Edwin
As a final touch, God created the Dutch
