OK Tested! :)
Touch mode must be disable else cursor tablett will made double use with the Mouse cursor
and when you click mouse it's the cursor place tablett who make the active function!
Works fine with MOI ...except (before find some tricks)
- you can't use the Right Click !
- you can't use the Mouse wheel !
these functions are used by the tablett and seems not disabled
So use of some icons are needing!
Except that all works at the same speed than normal!
The click mouse must be more long than normal for show a grey circle who integrates the click!
So using Moi on tablett is possible with some pleasure!
