>Max's one doesn't do that because it makes a surface for the arrowhead
>and surface trim boundaries are not drawn with mitered corners between segments.
>If this is troublesome I guess I could make a setting to not miter the arrowhead tip.
Thanks for the explanation.
I would prefer the drawing to be as sharp as possible when adding dimensions if it's not too hard or heavy on display performance.
Michel
